DougBoy66
I had been looking to get a Pop tester. Seemed like all the ones that can be bought are iffy. If this is old news I apologize.
SO, I read up on OLDBULL8'S bottle jack build. It is great. I am just very novice at welding so, I kept looking at video, threads and PDFs. So I came up with this no-weld (other than JBweld)bottle jack type tester after combining some of what I thought were the best things that each different ones had done
I made up a list of parts and got to it. First a 2 ton bottle jack. Has to be the thread on top type. Not welded.
So I disassembled it and drained all the jack oil out and removed the ram, I did not use it for this build. Next I threaded the inside of the stand pipe with a 3/4npt tap
I inserted a 3/4" x 2.5 inch nipple into the now threaded inside if the ram tube. I am just test fitting at this point.
There are bleeder holes in the cap nut that I tapped and inserted allen set screws with JB Weld on the threads and over the hole areas
Also had to drill the hole in the cap nut out to1-1/16 (slightly larger than the OD of a 3/4" pipe)
