Another Crew Cab 6.9 Rebuild Update
hesutton
The Anti-Anderson
Bowling Green, KY
Goose has that issue. His intake was a bear to get bolted down
You two are making me nervous. Keep it up and I'll test fit your man-i-folds with a claw hammer!:backoff:eek: :D:angel:
By the way. I ordered a set of Comp Cam's 910 springs. I was wondering about the increased pressure causing accelerated wear, but not after reading a bit and talking it over with Big Ron the Rally Host.;Sweet
The spring swap may delay getting the heads on, but I've got lots of other stuff to keep me busy.
Heath
Dsl_Dog_Treat
Decatur,MI
Heath, on that intake, just start all of the bolts a couple of turns. Ya know, just enough to hold them in without stripping out when ya start turning on em.
Like Corey said, John's was a PITA with decked heads.
A 7.3 I had to fix a shops screw ups a few weeks back also had decked heads and was the same way. Starting the bolts and wiggling the intake around while getting them all started helped ease the pain.;Sweet
tke395
