m67tang
I just replaced the v belts on my truck, all with the same size which I took off. The alt. belt size is 25-9580.
On the old belts the alternator belt would hit the vacuum pump pulley on the back side of the belt. I thought replacing it would fix it.
The new belt is so close to the same vacuum pulley it will hit as soon as it breaks in a little. there is no more room to take up slack without forcing it into the vacuum pulley.
What size belt do I need to use?
Any one else have this trouble?
thanks for the help.
