94turboidi
Okay I have been working on the truck as much as I can in my spare time. Today I am thinking I can button everything up and be done. I am putting starter bolts in, intake, batteries, oil....I started adding antifreeze. I put 3 jugs in and 2 gallons water. Then I noticed a small drip. It was coming from the front of the oil cooler. I thought maybe I didn't tighten the bolts enough, nope. It looks like its running out from the top bolt. Well I immediately drained as much antifreeze in a bucket as I could because that crap is expensive. Well I went on with trying to get the truck started. I put fuel in the filter and had some starting fluid. I kept cranking off and on and purging air out of the system. I had to charge it a few times but finally got it started. My glow plugs weren't working but I didn't have a wire hooked up. Well got them working but it still wouldn't start with out either. And when it did it filled up white smoke everywhere and ran rough. I messed with the timing and now it pops right off with the glowplugs. The motorcraft plugs stay on for 10-11 seconds, its awesome. I am starting to get frustrated because I took on so many little things at once.
The oil cooler isn't the one that was on the engine it was on my turbo engine and hasn't been ran in a few years but didn't leak when it was last on. I didn't take it apart just cleaned it up and painted it really good. I have heard something about o-rings, is this my problem? Once I get that fixed I have to bleed the clutch, brakes, top off ps fluid, antifreeze, rear ujoints, put drivers side battery tray in and battery (leaving out in case I need to take fender well out). What stinks is I put every rubber hose on the engine new but the lower radiator hose that came from rockauto was too short and I used my old crappy looking one. I might go ahead and buy one at oreillys since I have t his coolant leak to fix anyways now. Will I need new oil cooler gaskets? Mine are brand new but I am assuming there is going to be antifreeze and oil all over it when I take it off.
I need to get it properly timed when all done I think its still a bit retarded I am going to advance it some more when I get a chance to work on it again.
