GREASE FIRE
i almost bought this 89 f250 with lots of new parts & a new paint job for $2K from this guy who has been tinkering with diesels for longer than i have been driving. One of these people who can do anything probably but has too many projects going on and can never get himself to do anything totally the right way. Case in point: the glow plug relay went out so he did rig up a manual switch for it but he also had to rig up a seperate starter switch because the key switch was not working right. so instead of putting them each on seperate momentary push button switches he put them on the same one, so the starter cranks while the glow plugs heat up at the same time, and it doesn't work so well in cold weather so he just gives it a shot of starting fluid!!
what kind of damage do you think this idiot has done to the engine? The only possible good is that the glow plugs don't stay on more than a second since it starts right up with ether. He said he has been using starting fluid for years on all kinds of diesel engines - the only exceptions are the ones with aluminum heads - and has never had any problems. But he never keeps any of his rigs very long, just toys around with them and sells them for less than he put into them evidently.
Basically, can anyone tell me what kind of damage could have been done to this engine? supposedly he has not driven it much in the 1 1/2 years since he had it and even less in winter - maybe 10-20 ether starts he said.
is it still worth buying this 7.3 with 160K?
thanks,
paul
thanks,
paul
