GenLightening
Yeah, it's a CHEVY!
You may want to try (or have him try) to remove a couple of the glowplugs and see if they've swelled at all. If it ever took a bit to start it, and the gp's were on the whole time.....
well, first of all he only had it for 10K and the original owner had all maintenance done at dealership.
and, he did put a new glow plug relay (the manual type, basically a starter solenoid) but the dumb thing he did was connect the starter solenoid and the glow plug relay both to the same momentary toggle switch so you had to crank the engine while the glow plugs were heating up - then once it fires you let go of the switch. Not a bad setup for summer days but really poor for cold weather - hence the ether.
Paul
tonka-I personally still wouldn't touch it but that's me and my peeve about cobbed wiring. I absolutly will not buy a vehicle that anybody has chopped into a single wire in the factory harness. It's about the first thing I check when looking at used trucks and cars...... I pop the hood, look under the dash and look at the harness for the tail lights..... If I find one chopped/spliced wire, I leave.
Good luck
id stay away from it becuase you never know what the dude probabbly hilbillied to get it to run...
All I know is just here say, factory ether injection is a new one on me. Theres another wrinkle in the ol'brain!
My truck has a fitting on the cover of the air cleaner lid that looks like it is there for an ether line to run to. I never understood why it would be there when these rigs have GP's. I do not know, but I just always thought that in the heavier Int. trucks, maybe they didn't run GP's and that was the way to fire them up, but still didn't make any sense why Ford would use an Int. air cleaner?????
Just my confusion out loud.....
It won't hurt anything, we use it all the time to get engines started or primed.that fitting is for diagnostic purposes. the international air cleaner is bigger, and all 7.3 and 6.9s ran glow plugs regardless of what vehicle they were in
matt
