Camarogenius
Well, my air leak problems continue.
The latest is my rear tank. I put 8 gallons ($20) in my rear tank, and in 38 miles, it's running out of fuel on the rear tank. Since I've had the truck, it's had about an 11-12 gallon capacity in the rear tank, now, while it's over 2/3 full, the guage doesn't work, so I go off the odometer, it's running out of fuel.
How high up do these pickups break off?
Also, if I have a leaking rubber line somewhere, that's letting air into the system, then when the engine is running, with pressure in the fuel system, wouldn't there be a fuel leak?
This is driving me up a wall!!!!!
