tbrumm
I know the subject of air intrusion in the IDI's has been beat to death, so one more thread about it probably won't hurt anything. A couple of my injector caps were leaking a bit, so I ordered out a Dipaco return kit and replaced orings, caps and hoses. I still had 2 leakers so I installed viton orings. That dried up the caps and return lines, but the truck became even harder to start. I then replaced the 3 fuel olives with new Dipaco olives just to be safe. The filter was still draining out so I started checking return lines from engine back to tanks. I did find a place where the plastic fuel return line just behind the motor has rubbed on the cab, so I replaced that. All other lines looked fine. The FSV was replaced last March because it was leaking air. The mechanical pump was replaced last October with an actual Ford unit because the old one had begun to weep. New supply hose too. And disconnecting the incoming fuel line at the filter shows the line filled right up and it is not leaking back. Checked the Schrader on the filter and found some air bubbles under the cap, so I replaced it with a viton schrader so no leak there now. The water bowl on the filter was replaced last fall with new WIF sensor, new schrader and new drain valve. New fuel heater and oring at that time as well. Also just replaced the filter return fitting with new check ball and spring. I thought maybe the filter gasket might have a leak, so I installed a new filter. So, I have done all of this work to try and solve my extended cranking times only to now have extremely long crank times. The filter is really draining out and fast after shut down. The truck runs great once the filter fills back up. To try and pinpoint the problem, I installed some clear line between the IP return fitting and the return cap on No. 2. The clear line fills up completely with fuel and stays there with no bubbles even after truck is shut down. I installed a clear line between the filter return and the cap on No. 1. When running, fuel runs out the filter return and down the the cap. The clear line fills up with fuel for about two inches up form the cap when the engine is running. The fuel stays there in the line for a few minutes after shutdown, but then the bubbles start to show up and the fuel quickly drains away. I would say that within 10-15 minutes the filter has been drained and very long cranking is needed to start back up. The return from the IP still stays full of fuel regardless of time elapsed. I should note that this is happening with both fuel tanks full and with the truck on level ground. This happens when switched to either tank too. I have double checked all the return caps and all appear to seated correctly - they "clicked" into place when I installed them- and caps and hoses are still dry. I am about to the point where I am going to remove all the return lines, caps and orings and start over. I hope someone has some suggestions, or at least moral support that will help keep me searching for the leak. Thanks in advance guys! Todd
