quickster
Hows it going all. Just installed a rebuilt IP and having a hard time getting it to stay running. I installed new olives on the hard lines, and everything is tight. I got it going and was running fie,but the idle started oscillating up and down, then sounded like it running out of fuel, then died. Pulled off the filter and it was half full. Put on a clear return line from filter head to the injector and I'm getting spurting air. Filled the filter, bled out a couple injectors and got it going. Started with the air again-fuel for 2 seconds then air-fuel two seconds then air. Stayed running for a while but the idle got erratic like it was running out of fuel, then died.
I changed out the return lines last winter, the o-rings on injectors today. New fuel filter , what else? The only hose I didn't get to yet is the one leading to the lift pump from the hard line. The one thing I don't have is the check valve on the filter head. That would be in the brass 90 fitting with the return line, correct? If this could help me out, where can I pick one up?
Also, the plastic caps should snap down oner the two orings,correct? They are a ***** to get down.
Anyway, some feedback would be helpful. Almost all day working on this and still not right. Think International might have a check valve?
Thanks Jack forgot--this is for the '87 6.9
