air intake questions
88beast
pa
ok i have an idi and i want to add an air intake heater cause gps dont last long
so anyone have any info on the psd intake heaters i was thinking 2 or 4 of them would heat my idi but id like more specs thanks
Double-S-Diesel
parts seller
derry pa
dont really have any specs on them , other than none of my trucks have them, for some reason they dissapeared and a plug is in there place.
88beast
pa
ok i get it yall hate um here does that mean id need more than a couple to make it worth while? i know they are supposed to reduce velocity and all
Double-S-Diesel
parts seller
derry pa
2 of them would be about the same as the grid heater in a dodge
as far as 1 starting a IH motor, a psd with no glow plugs and a working air heater will not start still
a psd with 4 glow plugs will
my old idi with 6 glow plugs started all the time
88beast
pa
well im sick of the gps they burn out short and break off too much matience the good ones are discontinued and finding a goood 12v plug is hard too
trackspeeder
Stone crusher.
North Branford. CT
The AIH isn't used for starting purposes. It's job is to cut back smoke while idling. So it would require a few of these gizomos to actually start the engine cold. Better off fixing the glow plugs. Way more efficient.
Mutley
Ontario
Tom....major photobucket project there. Got any threads on the building of this thang? :sly
88beast
pa
ya over on tds i got a few and some on here in the idi section
i held off on the build because i got on this site and realized theres a lot out there for it
so now im doing this bronco then putting the holset on my truck then that motor unfortunatly but i worked out all the math
