Adhesive Advice
sjwelds
Central KS
Ten-four.
What about the 93-94 trucks that came turboed from factory? Didn't they have some extra badging of some sort?
Yes,
Under the F-X50 badge on the front fender in about 3/4 inch high letters was a badge that simply said
TURBO DIESEL
It was a raised badge, similar to the 80-86 F-X50 on the fender.... It was not a sticker like the Power Stroke Turbo Diesel trucks had
To the OP, I've always used the 3m automotive double side tape. Into the subject of the badges, they pop up on flea bay from time to time. I have not seen repops of the diesel badges. I was actually considering trying my hand at making a set out of billet aluminum and seeing how they polish up. I have access to a CNC mill that would be perfect for this if I can get someone to help me with the code. I'd probably make them bolt on from the back instead of just location pins in plastic. But that's a project for when I have time.
Sycostang67
Scooty Puff Junior
Kuna, ID
I second the 3M double sided tape, had lots of luck with that stuff. Another option is to use "The Right Stuff", it's a gasket making material but a great adhesive as well. I have used it to glue trim, badges and even side view mirror glass back on.
