Adding PW & PL
82fordtruck
NE Kansas
I purchased some doors and fenders, etc.
They have Power Windows and Power Locks in them. Can I connect up to the truck for power and just use them like they are? One door has two plugs - one connects to the cab, and the other goes over to the other door. I assume they just have power to them, but don't know.
Anyone have grey door panels for a 95?
Anyone want Body parts? Many I am replacing are in very good shape - or even perfect.....
I also have an automatic tilt, cruise column.
metrojd
Pittsburgh,Pa
Power doors
I dont know what year you are working on.
I Pulled the power harness out of an 88 CC.
There is a harness that goes from door to door and gets power on the driver side.
The harness is jambed up behind the dash.
It was easer to pull the dash to get the harness out because it runs behind the defroster duct work.
John
82fordtruck
NE Kansas
I've got both doors and that harness. What I really need to know is the other connector gets power by the e brake pedal. Is that there on an XL?
I also need door panels if anyone can help with that.
82fordtruck
NE Kansas
Upon closer inspection, the plug is there - it's being used to run the door speakers. There is aplug on each side, and part of the door harness that goes across the cab.
It appears that there are 8 wires going into the door harness, so I'll be OK. I couldn't test it out however.
crispy74
