Acetone in Gasoline
OutofOrder
I have been adding 1 ounce of acetone per 5 gallons of gasoline for 4-5 months now. My fuel economy has improved from 20 to 23mpg in town, but I have not had the chance to test it on the highway yet. Has anyone else experimented with this yet? From everything I've read online, there seems to be quite the disagreement over weather the small amount of acetone will damage any fuel system components. What is everyones' take on this?
Mike
Stroker
Cora
I experimented with acetone in DIESEL on my 95. Results were totally inconclusive and I stopped fooling with it. My end summary was it didnt work.
OutofOrder
How long did you try it? Are you aware of any damage to your engine or fuel line parts?
Dieselmaster
Diesel addict
Lake Havasu - Arizona
As it's a solvent, I would be worried that it would be leaning out the fuel causing more wear on internal parts....
A lean race motor will run like a stripped ape for a while..... then it goes boom!!
SHIP4BRAINS
Central Iowa
I used acetone in my 1999 Dodge Neon with positive results. I think I was mixing 2 oz per tank and seeing a 3-4 mpg increase. That neon was a 5 speed manual and I was seeing a consistant 39-40mpg when driven in a conservative manner. My 2005 Neon won't even come close....best I have seen is 32. POS.
SHIP4BRAINS
Central Iowa
2 oz to 12+ gallons of fuel should do no such thing
blender
Denham Springs, La
Methanol... That's what my buddies run, last motor he only got 32 passes on before ignition. Two pistons wedged sideways in the cylinders, pretty nasty.
Maybe he put a gallon of acetone in with his 10 gallons of Methanol to get better mileage in the quarter... :)
JLDickmon
Bo Duke
49041. OU812?
all has to do with how much oxygen is liberated (as in the case of NO2, or consumed, as with petroleum fuels)...
that's why A, AA, and TF cars have to wear blower blankets.. mixture gets too lean, cylinder temps get too hot, melts a piston, backfires into blower, kaboom.
