ABS light
no mufflers
rhode island
I am wiring a utility box on a 1997 f350 7.3 PSD and I cant get the brake lights to work. I am testing from the larger round plug at the end of the frame. other symptoms are, ABS light flashes 16 times, turn signals don't work, no power at brake switch. marker lights do work
here is a pic from my scanner of the possible codes. it is #16
Seems like a multitude of things.
12 relates to the fluid level sensor on the master.
11 would be worth looking at. Plus, brakes over ride turn signals/flashers.
no mufflers
rhode island
I am getting power to one of the flasher terminals but no power at either of the brake switch wires.
what is the multi function switch?
no mufflers
rhode island
ok, il check those things out.
is there anything else I can check that could cause the problem?
kbeck
