A/C change and update
Knuckledragger
Payson, AZ
I have been running without air for 10 years and now that I am making a few runs into AZ, it seems like it is time to get serious about updating my A/C system. The R12 is long gone, although I have never opened the system. It never worked the few times I switched on the A/C.
I have been reading about updating the system to R134a and am ready to replace the compressor and drier anyway. Looked on RockAuto and found a kit with Compressor, drier, O rings and other parts I might need for only $225.00. I remember reading that R134a needs a different orifice valve than R12, anyone know the difference, or what valve to order?
I am a wrench turner (I did build the engine) but have no A/C equipment (gauges, vacuum, tanks, nothing). I figure to install everything and then take it to the A/C shop and have a vacuum pulled and the new gas installed to finish the project. Sound reasonable, or just a waste of time?
Thanks for any guidance or help.
Kizer
Denton, Texas
I just put a Murray branded FULL system in my truck (Reilly's) with zero A/C experience.
I did my interweb research and rented/borrowed all A/C specific tools from O'Reilly's.
It took me all day ... after $100 rebate, I've got COLD air for about $560 including R134A.
Kizer
Denton, Texas
The orifice tube that I used was blue ... parts jockey said that was the correct one?
I don't have much A/C experience either. I will be following this since I HAVE GOT to do this to mine too.
Knuckledragger
Payson, AZ
Could not help but buy this deal. $233 including taxes, shipping and RockAuto discount. Now all I have to do is find time to install it.
chris142
SoCal
When you retrofit to r134a from r12 you use 15% less refrigerant. This corrolates to an orifice thats 15% smaller than the stock blue one. The orange one is the best choice.
WAID
PDX
I recently did mine and put a red tube in it. Reports seemed mixed about red vs orange but my system seems to be working well.
Kizer
Denton, Texas
He sold you an R12 tube. It will work ok. Better with the orange one.
Well crap. It's working well so I won't be changing it out ... unless it's going to be ******* my new system.
I don't really understand the function of the orifice tube.
Can you enlighten me?
Thank you
Thank you
Maybe this will help you.
chris142
SoCal
Basically It makes the system go from high pressure to low pressure allowing the refrigerant to boil on the evaporator and getting cold.
Big Bear
