Fuel Line Olive (installed on line)
Isolation from vibrations would also be my guess.
Although there are a LOT of diesel engines that use the simple flare fitting
on steel lines, and seem to have no problems (as long as all the line clamps
and holders are still installed).
If you will notice, the 2 lines that the IDI uses olives on have no other support.
That could be the reasoning here.
Thank you for that. I was working off a sample of one, which looked factory stock when I got it.3 lines!and the return line does bolt to the intake.
the LP to FH line , some are clamped, some are not, i think factory, they had a clamp on the side of the filter head bracket.
