94 7.3l idi heads needed
Robm45497
Mead wa
hello im doing a new build on a 94 idi turbo and i have cracked heads. looking for any good cores or heads thank you
Hydro-idi
Lodi, California
Unfortunately, you likely won't find a set of cylinder heads without cracks in them, unless they are brand new. Some cracks are considered acceptable and some aren't.
I went thru 3 sets on my engine build before realizing I wasn't going to find any heads that were crack free. Ended up having my machine shop guy put pins/lock n stitch in the cracks on both heads. Was very happy with how they turned out and didn't cost an arm & a leg.
It can be easily done if you find the right guy to do it.
Might be an option if you can't find a good set.
MTKirk
Billings, MT
I would go with heads from Diesel cast welding http://www.dieselcastwelding.com/ They are expensive, but the heads will be crack free (they repair them) and they have new precups and know how to install them correctly. I prefer doing business with the Minnesota location even though Portland is closer to me.
