93 turbo cdr Does the cdr
94 1st GEN
Tx
Is the cdr valve on my 93 7.3 turbo idi supposed to keep oil from entering the turbo,oil pooling at opening to turbo
rhkcommander
Oregon
A cdr is supposed to provide relief for crankcase pressure, if you have a lot of oil coming through it can be a sign of engine wear, bad rings if I recall.
You'll get some oil from any of them though.
SLC97SR5
UT
My experience is that you will always get some measure of oil pooling at the turbo inlet, right in the depression of the filter hat to turbo boot.
My new engine has significantly less pooling than my original but aside from the acceptable blow by there is the coalescing of the hot oil vapors that occur after shutdown.
It is akin to the visible vapor that escapes the oil filler cap on a recently run engine.
truckonfire
