92 ish cube van tear down
So with everything going on...Brian is parting out a cube van to make into a trailer.
We are popping cab off and pulling emgine.
If engine checks out ok...its sold.
Other parts available...
Should be a great project.
attachment.php
attachment.php
Cant wait see how this works out.
Thanks for looking.
Got cab off no big issue.
Next is fire, run, comp test and done!!!
compressionignitionrules
Bluevale ON
that's how you do headgaskets in a cubevan:rotflmao
cube vans are getting cheap around here, running driving under $1000. minor repairs to safety even. I got a 2001 E450 for $650 and drove it home over an hour under 190,000km , saw a 2002 E350 on kijiji tonight for 900 in mississauga.
never seen a cube made into a trailer , cool idea? I'm watching;Sweet
You have it posted as a part out. Make two posts then. Idi forum is not intended to have parts listed.
It was never intedned as a sale part out...just a project part out.
Really nothing to sell other than engine. It is tentatively sold.
The rest is getting scrapped.
As for runaway domajiggy....ya dont freakin think so...thats a KEEPER fer me!;Sweet
Took plasma cutter over to Brians to blow the 6 body bolts and such...was easy peasy...
That engine will be tested this weekend and then sold or scrapped....if scrapped....core material.
Told it runs good by my friend...so hope so he moved to BC with it and it seemed to run fine when we had it going here.
Trailer will have an AC unit stuck into it and used for hanging a deer.
Lots of fun.
Comp test results today...
Holee monkey arms...3x each cyl...av readings...low # is 1st comp stroke...hi # the cumulative after 5 or 6 rev
1 220 440
2 200 440
3 200 450
4 210 430
5 210 440
6 220 440
7 210 440
8 220 450
Not too shabby eh
Thanks for looking
I hear a knock Al........:rolleyes::eek::angel:;p Just teasing ya.. Sounds very nice. Was this an oil field rig? The air intake shutoff valve seems to say that. In the last vid you give a great example of a bad fan clutch by how it kept spinning after shutdown and the dirt accumulation around the thermo spring from the failed shaft seal. What caused the trans oil leak and you say it will be a trailer to hang a deer in??? I'm guessing a mobile game dressing refer rig.. Nice idea really...:thumbsup::thumbsup:
Yes Gary ex oilfield rig.
Ya I will knock fan clurltch off so it isnt used.
Sure a stupid spot for the teardown part out thread seeing as nadda fer sale.
Thanks for looking...
@Dieselcrawler
Maybe stick you can it back in idi forum since not selling poo poo except engine...just parting it out and scrapping most.
Just saying....I had it where it shoukd be in first place....if was selling all parts would have listed them here...:rotflmao
Dieselcrawler
Professional wrench holder
Quakertown Pa
Should of moved it to the dumb and dumber forum. Getting tired of you guys clogging up the tech areas with this useless crap. And knock it off with the cursing in open forums, I know you have been warned before about this. And no, adding an e to the end doesn't fix it.
Well progress of unit.
R12 tarp rolled out on roof...AC gets it down 60F we need a manual thermostat or a way to lower it more if possible.
Engine is removed and power washed.
Lil cleaner now eh.......now to pull starter trans fuel filter and ex manifold and prep for shipping.
Trailer will continue to get worked on.
Thanks for looking.
Big Bear
