92 f350 idi wont start after reaching operating temp.
David Johnson
Hi guys. I just bought my first idi and its having some issues. It starts fine first thing in the morning but after running for 15 to 20 mins if you shut it off it WILL NOT crank for a couple hours. Kind of the opposite of problems ive had in the past . Also its a automatic and runs through all gears fine but slips in reverse. Im excited about getting this truck from the research Ive done these idi engines look really tough and wallet friendly. TIA.
gandalf
Senior Member
CA &/or Maine
You say it will not CRANK again after it warms up. Do you mean that the engine will not turn over, or do you mean the engine will not fire? If the engine turns over but will not fire, try pouring a glass or so of cool water over the IP. Cool, not cold. If it will then fire you have a heat soak problem with the IP, and will most likely need to replace it. If it will not turn over I'd start looking at electrical.
Very good point on cranking speed, and thank y’all for the recommendation
Op, start by cleaning the battery, starter and ground connections, I know in my climate that if I don’t clean them every other oil change the cranking speed will start to deteriorate. If that doesn’t seem to have an affect and the engine seems to already spin over well when hot, there’s a couple pump adjustments that can temporarily fix some hot starting issues, but you will need a pyro first, and if it turns out that your pump needs to be gone through I’d be happy to rebuild it for you:)
David Johnson
The water trick didnt work. Its kind of odd. Yesterday i ran the truck for approx 1 hour. Shut it off. Restarted after 10 seconds no problem. 10 mins later it would not start. How much for a rebuild and where are you located.
[QUOTE="Thewespaul I’d be happy to rebuild it for you:)[/QUOTE]
the VERY first thing I would do is to see if you have 12V going to your FSS on the injection pump during the no start condition
Dirtleg
Cloverdale VA
The water trick never worked for me. I had the same issue. It was a worn IP.
The reason it will restart right away but not after it's sat for 10 minutes is that the IP heat soaks more after you shut the truck off than when running due to the fuel not flowing through it anymore. Once it's been sitting a bit it is fully heat soaked but not so much after initial shutdown.
It's always recommended to replace IP and injectors at the same time and I would if you can afford it. If not I've done just the IP and gotten by but it ran much better once I got injectors as well.
Since the water didn’t affect it you could check to see if the pump had power, you just disconnect the front wire connector on the pump, and with the key on you will here a click as connect it back up. I’d still lean towards a tired ip being your cause. My are typically between $750-900 depending on condition of the core and what modifications you want made to it, if any. I’m located just north of San Antonio, TX.
zemmeron
