my 92 250 dies when i let off the accelator runs fine, will idle as long as i dont let off the accelator fast i am thinking the govinor in the pump is bad, any one had any luck with additives in the fuel or do i need a new injection pump?
thats about what mine is doing thanks
i will get a new tank and go from there, and i will try the fuel filter with atf while i am at it needs a new rear tank anyway, thanks for the in putIt was suggested at the time by someone here that it might be the metering valve sticking. But I never looked into it, since fresh fuel was enough to fix the problem. You may try the ATF thing above, but also get some of this and just take it out for a long drive on the highway to let things flow and move to help free up sticking things:
Mine started doing that a few years ago after I got a tank of bad fuel. I did the ATF in the fuel filter trick and it fixed it.
thats where i will start thanksMine started doing that a few years ago after I got a tank of bad fuel. I did the ATF in the fuel filter trick and it fixed it.
