D.A.V_Oil_Brnr
M88 Junky
Hello everyone.
I am rather new to the diesel genre even though I am a disabled U.S. Army Abrams Battletank Mechanic. I have a 1986 Ford F250 XL Supercab Diesel 4X4 (6.9L). It has the manual transmission and a gear vendors over-under drive unit. Also has a nice front workbench, I mean ***** bumper which has a M12000 Warn in it. Truck has a few minor issues, but is solid and 98% straight. Been lifted a little, but looks done well. I believe the Front Twin Beam Axle is the Dana 50, but I must have one of the non-stamped ones if it is as I am unable to find the stamping. The truck was once owned by a electrician and so it has a ton of household electrical wiring in it that I am removing little by little. And, it has drivers and passenger unity spot lights I have to replace as both are rusted and worn out. The dumb jerk that owned the truck before me decided to be a pot smoking braniac and "go green" by filling the truck with 100% biodiesel with no filter change or anything at all. After replacing several parts he damaged, I ended up buying the truck from him and it actually runs in my care (seeing as I know what DIESEL is). At the very least, I got the truck to stop smoking. The only problem I have is that i need a new dash panel, and I have to find out where the fuel lines are sucking air.
Which brings me to this forum. I would like to toss myself in the laps of a few of the knowledgeable oil burners to make sure I know EVERYTHING I am doing with the old girl. I have a tool collection started, enough spare fuses to supply Fort Knox, and 2 repair manuals from Haynes (one diesel engine specific). I can grab a few pictures For those that wish to salivate, just ask for them. After the dash panel and fuel lines, I have to fix the fuel gauge and find out why the engine light keeps coming on (I know the engine seems to run cold....). The glow plugs are new, the harness has been redone (by me), both solenoids are new, the main positive and negative battery cables are new, the lift pump is new, the fuel filter and water separator filter are both new, the alternator has been tested good, and the regulator is new. The brakes seem to be a touch soft in rear so that is a project once i find a spot to do it. I installed a special edition cobra CB with twin phase antennas (and because the antennas got jacked, I have to replace the antennas and mounts for about $100.00).
All in all, the truck is good. Just needs a good owner. Which with the help of the oil burning special forces, I hope to be one. So any questions, ideas, concerns, general comments, or anything not covered is fully welcome. It's why I posted here after all.
p.s. : Mid post once I finished with the text, I decided to just go take pictures with my phone. I will post what my phone took, tho there will be doubles as my phone takes pictures differently than I am used to and I have not taken time to learn what is what. I am an idiot with an android phone, but put me next to a vehicle and look out... Also, I apologize in advance if I post to many photo's en masse.
