70's F-500/F-600 with C-6 trans
whd507
Highlandville Missouri
anybody know where one can be found? I want a parts truck with this combo, or really just the steering column and all the linkage. I want to put a E40D in the F-600, but finding one from an F-superduty F-450 (because it has the E-brake on the tailshaft) is getting hard to find, the only one I've found they want $2k for...
I figured a C-6 would be stronger, and an aux trans could be installed later. my bigger tires should help a little too.
if you know of one in the western states, or where parts can be located, I'd appreciate it
Haulinhazmat
Fredericktown, MO.
F-600 Parts truck
Hi New guy here with first post. I would suggest you not over look the F100 thru the F-350 for cab parts. F-100 doors fit the F-600 and the seats and dash parts from a f-250 bolt right in. Check out that steering colum you need. Worked for me. :D my .02
Duke
PA
Haulinhazmat,
WELCOME TO THE SITE!!!!! Please hang out and throw your .02 in whenever you want. ;Sweet
What kind of hazmat do you haul and what do you haul it in?
whd507
I have lots of little trucks for various parts, but the pickup door handles are impossible to open on a bigger truck, because you are below them.
the floorplan, and steering column are wildly different also.
the reason I'm looking for one with a C-6 is I can use those original parts to use an E40D in this truck. they were optionable with a C-6, but I've never seen one.
Haulinhazmat
Fredericktown, MO.
parts trucks
I can't remember any problems I had but this was on 73' model year trucks in about 1996 so age has taken its toll.
Duke. I retired in 1999 after 30 years on the road. I pulled tankers hauling Liquid Hydrogen we were the guys who filled the space shuttles.
Ggg
Northern IL.
Roland_Jenkins said:
A ford FMX transmission would also work for you.
I wouldn't think a FMX will hold up to a well built 6 cyl in a car let alone a medium duty truck.
whd507 Welcome to the site. I have worked on a lot of those series F-trucks but I do not remember seeing any with a C-6. The only autos I ever saw were Allisons behind diesels. So the C-6 must be a real odd option.
Jarlaxle
Bregan D'aerthe
New England
Do not desecrate this truck with a slushpump! :mad:
If you must, look for a 1997-up E-Super Duty/E-450 for the driveline-clamp E-brake.
But, you really need to hold on to the handshaker. :p
Copper
The only F-series trucks I've seen had a Morse tower that hung under the dash - I suppose then the column wouldn't necessarily be different.
olsen726
