h2odrx
Anti-O
Ok, The 87 has not been used much in the last year. I started it up the other day and was letting it idle cold it has 60 psi if I sit there and hold it to 2k rpm's it climbs to 70 psi?
I have never seen it that high? The thing reads 20 hot idle and 59ish at 60mph.....that is normal when cold.
Cool!My IDI used to go up to 75psi when cold and I reved it up, then when warm it ould be around 45psi high idle and 20psi low idle.
Cold oil makes way more pressure than hot oil. Don't know what my truck makes, but the diesel ranger will go above 100 PSI when reved up cold, and settle to 20-25 psi when idleing hot.
My truck when cold idles at about 25psi, then about 10-15 when warm, highest I've ever seen pressure under load and warm was 40 psi...
Presumably a younger engine will have lower oil pressure because the galleys aren't clogged up? Oil pressure is one of those weird things to figger out...
