I pulled it and parted the truck. Put the engine in the garage and just deemed it a builder. Prolly a burnt exhaust valve. Saved it since it's a turbo block
Like the previous said this is an old post but I seen this post last night and had to comment. I have had to 7.3 IDI engines. Both of them had badly worn exhaust valves. These guides get so bad the valve wobble side to side and makes the misfire. This is what happened to me twice. It is due to an update with Ford for valve stem seals on the exhaust side. This cut down on emissions. But cost us engine problems later in the years. I hope this helps someone that reads this post. Thanks southern militia
