Took me awhile to get around to this beast but work has been go go go go go...... Here are the compression results.... Cylinders #1 and #2 have 240psi...... #3 is 310psi, #4 is 410 psi, #5 is 400psi, #6 is 360psi, #7 & #8 are 350 psi..... The engine has a huffing noise out the exhaust like its running on 7 cylinders and makes the truck shake also.... Excessive blow by once warmed up... Come to find out it is a jasper reman with 120,000 miles on it..... Floored it a couple times running the engine up to 2500 in neutral and it smokes like a train , so who knows what has happened to it, could have a burnt piston from excessive egts...... Anyone else have any input to what may be wrong? I believe I'm going to just part the truck since it has a newer rebuilt e40d and trans case with 20,000 miles on them... and I have the paper work to document it
Paul
