Hey guys I have this f350 used to have a 460 but we did a 7.3 idi swap and installed an ats 088 turbo kit on it we got cheap. This is a pretty heavy pickup stock with a custom flat bed it weighs about 8600lbs empty. The problem is that the best boost I have gotten out of it has been 6psi and that was climbing a 7% grade on flat ground I'm only getting 3 or 4 psi. I know these turbo are kinda weak anyway but I'm thinking it should at least put out 8 or 9. I considered getting a different t4 cartridge and installing the ats housings on it but not sure if the housings are why it doesnt want to boost. Anyone with insight to how I can make this turbo set up boost better it would be appreciated.
Sent from my LG-H700 using Tapatalk
