AmboIDI
I've read that the black holley pump puts out too much pressure and the IP only needs a 4-6psi lift pump not 9-14psi like the black holley puts out.
Can anyone else weigh in on the best electric lift pump for these?
As for advancing the IP I plan to do a static advance by loosening the IP from the gear housing and turning it about 1/16" (like you did) at a time to see if that has any effect. Any reason why this method would be better or worse than skipping a tooth on the timing gear? Seems simpler and lower consequence than trying to get that timing gear just right.
Good call on the pyro. I should have done that from the start and am planning to put one in asap.
