When checking the output voltage of the relay, would you check it in the harness side or the relay side of the resistor? It IS a Solid State controller (apparently a very late 86, with bullet style connectors).
You check it at the output side of the relay (harness side), that way you know if you have enough voltage output thru the relay.
