5.0ohsoslow
I have a stock 6.9 except for little pump turn up and a stack. The truck started sounding like and old farm tractor about a month ago. Put-Put-Put... I noticed throughout the month (only drove it 4 times) the rpms droped from 700 to 525, along with the tractor sound. The other day I drove it and on the way home it started running even sicker, it started to pour on the gray smoke under very light throddle(egt-500), blacker under any more(egt 700-900) and hessitated seriously in 3rd and 4rth gears. The egt's stayed higher than normal even after I returned it to idle. I pulled off the air filter and a very very loud almost knocking noise acompinged the put-put! With the air filter on the "knock" is much much quieter. The motor also is shaking around in the truck much more than normal. Any more than the 525 idle it feels like it will take flight!!! The rpm increase is sluggish and higher in the rpm range 2000 can be accompnied with a backfire and popping noises.
I do not know about the life of the ip or injectors.
1983 f250 6.9 Granny Low
All help is appreciated!!!
