6.9 idi with zf5 trans
hce
So can i....
Glasgow MT (Official middle of nowhere)
The ba
But as far as factory N/A stuff, 6.9 or 7.3 is all the same balance and bolt holes, etc. What transmission do you have?
The bolt holes are the same, but balance is different. Took a few good size holes to match the 7.3 flywheel to the same 6.9 imbalance. Luk use to have a seperate part number just for the one year the 6.9 had a zf, but there are many accounts of using a 7.3 flywheel on a 6.9.
piperig78
Wisconsin
That is my concern I hear it both ways. Most people run the 7.3 na stuff on 6.9s with no problems, but there are/were different part numbers. Thank you all for the info. The motor is being rebuilt currently I think I'll get the standard LUK conversion kit and give it to my machinist then he can check balance on everything before it gets assembled. I will report my findings
