Bradley316
I know its absolutley insane but i already bought the engine so don't try and talk me out of it. i Plan to make this 1972 four door maverick an international 6.9l diesel engine powered car. I have a zf5 speed that im going to make work with it, the length looks like it wont be a problem at all. the height of the trans is a diferent story but theres nothign wrong with getting a little creative. That being said ive taken measurements and the engine will most deffinitly fit in the engine bay once i find a way to delete those pesky shock/coil towers that plague alot of those 60s/70s ford cars (mustang, falcon, comet, maverick etc). But there is the rub, I have it under suspiscion that the traditional method of grafting in a mustang two front suspension isnt going to be strong enough for the give or take thousand lbs of engine and transmission. The current idea is to graft in an 80s ranger twin ibeam set up, somethign that can handle a lot more weight and give room for the massive springs im going to have to run. It should go without saying im going to be cutting and welding thicker frame metal all around sub frame connectors all kinds of bracing and structure to take the weight of this big monstrosity. Any thoughts on The ranger front end or of anything else you think could work out better? the plan is to make this thing streetable and daily driven so no gasser solid axle nonsense.
UPDATE 10/23/2016: As many people may have guessed by now this project is on the back burner, like alot of these involved projects. However, i am still incredibly passionate about this project and cant wait to start on it. I have decided to go with the ranger front suspension as as template, and anything that even appears like it might come close to not being strong enough will be strengthened, reinforced, and if neccesary cut out and replaced with thicker steel.I like the way the i-beam set up attaches to the body. Everything that holds weight is going to be strengthened. Beefy engine mounts, thick steel frame, thick trans cross-member, cut the existing frame portions of the uni-body and weld in thick square tube steel. the main priority is getting the body strong enough to hold this heavy chunk of iron, everything else comes second. I hate to update this post without having any physical progress made, but in many ways the planning stage is a huge part of a project this big, so decisions made there are in fact forms of progress.
