6.9 idi doing funny things
Ethan Smith
Springfield oregon
So my idi does this crazy thing. It starts really getting torquey and rips hard right before it runs outta fuel. As if there's a fuel restriction and when the tank starts to pull air its either running proper. (I've got a racor prefilter before the stock filter) or something crazy.
Seriously dudes it's like a drag truck when I'm dipping really low into the tank. I can't figure out why.
Ethan Smith
Springfield oregon
Alright, no doubt about the air intrusion. But.im telling you guys it runs really well when that air starts intruding. It's running well enough as it is but it's like a drag car when it's running lean. I understand two strokes running lean and rippin about to burn the piston. But with less diesel it autta just big down? I know my timings alright but you guys are saying that as it leans out the timing somehow advances?
Yeah, they run really sweet just before they die.
Brian VT
Maine, USA
...just like a 2-stroke.
Most race drivers have the ability to lean the fuel mix out as needed near the end of the race if needed to win.
If the engine melts down just after the finish line then you know you gave it everything you had. And hopefully you won.
I've burned up some 2-strokes that were going lean and, YES!, they go like hell before they melt down.
XOLATEM
Virginia... in the brambles
Years ago...I had heard the same thing about chevy small-blocks...
It dawned on me later that it could have been the timing chain loosened up enough to retard the cam timing noticeably and that would make an engine run like a r-a-p-e-d ape just before the chain let go...
'We' don't know anything about timing chains letting go...do we..?
Not naming any names, you know...
It didn't let go, it just moved over a few teeth.
XOLATEM
I had a Jawa moped back in the 70's...I took the baffle out of the muffler, ran a hotter sparkplug, bumped up the timing, and put Sears gas in it...(you could get two grades of hi-test from Sears auto back then...IIRC...it was 98 octane for mid-grade and 108 for Super..!)
It ran better for a while...the engine must not have been broken in yet...
but...one night in the summer I was coming home from the other side of town...and I musta been a little lit from some bootleg beer...
I was going down hill and I decided to run 'er wide open and if it was going to fly apart...oh, well...
It was a two-stroke...and you know how they will run ok until it hits a sweet spot...(we used to call it...'getting on the pipe'..)
and then it cut loose and ran up to an RPM that I had never seen or felt before...
Sounded something like this...
(normal accel)..."BBBBRRRRRRRR....MMMMM....
(former top RPM...a 'burble'.." BUDDBBUUDDBBUUDD"
(then scary...like it was winding to the moon...)
"WWWAAAAAAAAAAAAAAAANNNNNNNNNNNN......"
First thing I thought was that it WAS going to fly apart..!!!
BUT...IT DIDN'T....YYEEEEEE....HHAAAAAAA....!!!!
After that night...if I was on level road or a slight down hill...it would do it kinda regularly...
I got the thing to almost do 40 MPH...I loved it...
Was it running lean, guys..?
Rdnck84_03
Kansas
Yup, it can cause some serious carnage. No idea how it was running beforehand though, I bought it in this condition.
The good news is that we don't have to worry about this in an idi.
James
JU57US
