rodman68
Can the 6.2 diesel be attached to a th350 trans. I am still trying to install a 6.2 in a scout II and I ran across a 74 that has the 250 chevy six cyl with a th350 and 203 transfer case.
not so for GM.I'm not familiar on what transmissions were behind a 6.2 but a TH350 is vacuum controled. If it should have a 700R4 that may be a problem.
THM400, C-6, and the TF727 are all the pinacle of track proven bulletproof detroit engineering. Unfortunately the TF727 has went by the wayside and the THM400 is now the 4L80E and the C-6 is the E4DOA or whatever it's current abortion name.Ok I was not aware of an auto behind a GM until the 700r4. So it used a setup like a Ford c-6?
Actually towcat has the vacuum valve for a 400 diesel truck, he could post pictures of it if he feels like it
