5.9 vs 6.5
Jcdiesel
France
Hello
Which is the better truck between a 1996 Ram dually cummins 12v 4wd extended cab manual transmission and a 1995 Gm dually crew cab 6.5 td 4wd manual transmission.
I read that the Cummins is good for heavy loads, and the 6.5 for highway driving. I know the transmissions are the same (NV4500). No heavy loads for my truck, just a Harley.
Thank you
u2slow
bilge rat
Coastal BC
IMHO, the truck qualities are similar and not especially great.
The dodge has the better engine, but the worse front steering/suspension. The chevy will be lower and easier to load a harley into.
Jcdiesel
France
The Peninsular has a forged crankshaft.
I've seen a lot of 6.5s on YouTube with broken cast-iron crankshafts.
Black dawg
sw mt
Broken crankshafts, blown head gaskets, pmd issues, those will be the days of your 6.5 life.
I do like the 6.2 and 6.5s, but reality is that a p pump 12 valve motor will more than likey give no trouble.....as long as the dowel pin is fixed.
Black dawg
sw mt
as far as the trucks, the gm is a nicer truck, and the real crewcab is nice if you can deal with the length of the truck. Those trucks typically drive really nice as well.
The dodge is ok, typically drive poor without doing 3rd-4th gen style steering stuff. But with the newer steering stuff (track bar) they usually drive ok.
PLANET AUTOMOBILE
France
The length of the Dodge is 244 and the Chevrolet 249.
not a big difference
I like the sound of the Detroit V8 and the style of the Dodge
but I think I'll go with a Dodge because of the reliability of its engine.
u2slow
bilge rat
Coastal BC
Those years chev and dodge are cut from similar 'cloth'. IME, both rust out structurally... faster than the generation before them.
u2slow
bilge rat
Coastal BC
Better truck than the other two. Engine falls in between.
Personally, I had some poor 7.3L powersteoke experiences. Prefer the 12-valve cummins.
