4x4 swap questions
fordbrother95
dreams of smoke
hope ks
hey everybody, i have my 95 psd 2wd and im looking to convert it to 4wd and i had a couple questions to ask and some ideas to toss into the air. i have a coil spring dana 44 lying around and im curious if it will fit under the spring buckets on my f250. if that wont work i will probably just put my cab and motor on a 4x4 frame at some point but hey why spend money on another truck if i dont have to lol. any insight would be awesome thanks everyone!
oh and i will be puting dana 60 knuckles on it for anybody who hought i would run a 5 bolt hub on my 8 lug truck lol
Even if you put D60 knuckles on it, it's still just a D44.
Just get a D60 from a F350. Make sure it's a SRW. Or you'll have to swap the hub, iirc.
Make sure to get the track bar and bracket. The F350 springs ride better, and will give a little lift, so get some F350 rear lift blocks also.
Need the F350 front driveshaft also, but some people talk about flipping a F250 driveshaft and just using it.
94f450sd
somewhere,ma
Dana 60 is not a bolt in on a 2wd coil sprung truck.
Yes you can go the easy route with the bronco/f150 front end parts withe the correct rotors and hubs.i believe there was a thread on whats needed in the idi forum
fordbrother95
dreams of smoke
hope ks
Ok thanks a bunch i wasnt sure what to do bc i dont have holes for front spring shackles
Sent from my DROIDX using Tapatalk 2
Leeland
Oregon
Rsk. Then the appropriate 60 is a bolt in and you will have a extra 3" or 5" of lift dependent on the kit you use. Keep hearing that they ride better too but I can't substantiate that claim yet.
fordbrother95
dreams of smoke
hope ks
What does rsk stand for? Sorry still new to the forum jargin haha...
Leeland
Oregon
Reverse shackle kit.
Basically you would be adding spring hangers that are positioned to give you some lift at the same time. Last I looked I think the 3" kit is $300 from sky.
fordbrother95
dreams of smoke
hope ks
Ok thanks i will do some looking around. What do i do about leaf springs? Just 1 ton 4x4 springs?
Leeland
Oregon
Don't necessarily need 350 springs but be sure they are diesel rated. There are small block f350's out there. Leafs from a f250 or f350 will work. If you can find a 60 with the springs, track bar with cross member mount all attached from a diesel you'll be good to go after the rsk is in place. Or you could just go get factory hangers but would be kinda a waste of time with the work involved unless you want a factory height truck.
*im not sure if there's a diff between 2wd and 4wd steering like older chevs.
Leeland
Oregon
Not a problem, everyone is here to help. If you go to sky's web site they have the install instructions posted with pictures. Will give you a heads up what your in for.
*install instructions can be found when you click on the product*
fordf350man
Rockwood MI
the reason for the better ride is because they use super duty springs instead of the obs springs, just doing a rsk wont give much of a difference in ride, probably wouldn't notice it, i was going to do this and did some searching, people that just did the rsk said it made no difference until they put the super duty front springs on it
Leeland
Oregon
Scratch that yes I did
Still heard they ride better though. Less wandering etc
Leeland
Oregon
Yeah I know. Just got off work and pounding alcohol...lol
-fawked-
