trucknorris
The previous owner played with wiring and snipped of the reverse connector. What reverse connector is it? I need to buy a pig tail for it, and splice it back in.
Second issue, when engine comes close to operating temperature, the tach becomes erratic. I'm pretty sure it's the cam position sensor, but I don't want to spend $60 to find otherwise. Is there anything else I should look into?
Finally, the last issue; 93 with cruise control, 4WD ZFS542, digital odometer.. where in the world is the speed sensor.. It's not on the tranny, it's not on the transfer case... The only speed sensor I found was on the rear transfer case... which I replaced, and it ohms correctly.. however, I still don't have speed or odometer.. wiring problem? doh :]
Other than that, I got my permanent clutch linkage fix in today. Pedal travel feel shorter.... but it works![Sweet ;Sweet ;Sweet](/styles/default/xenforo/smilies/Thumbup19.gif)
