adamsanders
I’ve been having to use my 4WD quite a bit lately and I’ve discovered an issue I’d like to get resolved. For some reason, my truck doesn’t seem to want to stay in 4WD. This only occurs in 4 Hi and the shifter goes in and out extremely smooth. Also, the shifter doesn’t actually pop out or move when this happens, I’ll just be moving along in 4 Hi and then come to a stop, and then when I try to pull out again the engine just revs and it’s as if my T-Case is in neutral. I can go back to 2WD, let out on the clutch a little, stop and it’ll go back to 4 Hi and work fine. Very rarely does it “pop out” while moving, it mainly just happens once I push in the clutch. I have a 1991 F-250 with a ZF5 transmission. Is there adjustment or something I can look at? Thanks
