I got the truck about 2 months ago ... i had a "mechanic " replace the seals.. it was fine for a week and started again. I think the oil is pumping into my gas... I put 8 gallons in to go from Addison to FT Worth... about 40 miles...
If it is going into the future then you most likely have a failed injector o-ring. Easy way to check and see if that's what's happening is to pull the fuel filter and see if the diesel is black.
