1993 Ford F-Super Duty XLT - "Log Truck" (new to me truck-pic heavy)
FORDF250HDXLT
Maine & Oklahoma
Oh boy, surprised no one has said anything about your use of Teflon tape. Lol
Just wait, someone (or multiple) will have a heart attack. ROFL
Good work, as usual.
oh yeah,they say to use the tape on the oil supply elbow.this is a place where i will use it like i did on the f250.it's because you need to get a good dose of it on there so it snugs up at just the right angle.not a trick ya can do with the pipe dope that i know of.
so there isn't much else to do with the parts im missing right now.i could ream out the firewall but i'l just wait and do it all in order.a lot easier like this,taking my time.for the f250 i had to get help and get 'er all done in a weekend cus i needed the truck.this truck has been more enjoyable.not having to worry about making sure it remains drivable with whatever im doing at the time.just stop anywhere and wait without worry.
iv got the 3.5" exhaust system ordered minus the 10' length of pipe.i went and picked that up locally yesterday.
[QUOTEOh boy, surprised no one has said anything about your use of Teflon tape. Lol
Just wait, someone (or multiple) will have a heart attack. ROFL][/QUOTE]
Kinda think this is pointed at me.
Don't think I'll have a Heart attack, but am having a little trouble breathing, Combivent helps a little, could be from 70 yrs. of smoking. Dr. said quit smoking, Naw, I'll just wrap the ends with Teflon tape, what say you riot. :rotflmao:rotflmao:rotflmao
FORDF250HDXLT
Maine & Oklahoma
thanks to the good folks out in Cali over at gale banks engineering,log truck is back on channel 444 tonight!;Sweet
just like last time,a quick call up to banks with a few part numbers of any part i needed,no matter how big or small and even though i didn't buy a turbo kit from them,they happily and promptly took my order and sent the missing parts i needed right out so i could complete my install.
so now with the few missing parts and the gasket set,we'll start by performing the temporarily skipped items as noted above.
back to step 8.parts C & D.
C. On 1987 and later models, Mount the glow plug
relay to the glow plug relay bracket (provided) using
two 1⁄4” – 28 x 1” hex bolts, two 1⁄2” O.D. x 1⁄4” I.D. washers,
and two 1⁄4” – 28 nylock nuts. Clamp the relay
ground wire under one of the nuts. See Figure 4.
D. Install the turbine inlet casting support bracket and
glow plug relay bracket to intake manifold using two 3⁄8
– 16 x 3” hex bolts and two 3⁄8 split lock washers. Leave
bolts loose. See Figure 4. Route the relay wiring, if
equipped, as shown in Figure 5.
attachment.php
back to the second part of step 10.
Install rubber o-ring in groove in manifold block-off plate. See
Figure 6. Install manifold block-off plate (and o-ring)
on intake manifold where anti-depression valve was
removed, using two 5⁄16” – 18 x 1” hex head bolts and
split lock washers. See Figure 6. Do not tighten bolts
at this time.
attachment.php
back to the second part of step 13.
Remove 1⁄8” NPT pipe plug for oil feed connection,
located on lower left side at rear of engine block,
above and to the rear of the oil filter. See Figure 8.
Install the shorter 1⁄8” NPT x – 4AN elbow fitting where
the pipe plug was removed. Use Teflon tape on the
threads. Aim elbow at approximately one o’clock position
when tightening.
A. Install and tighten one end of the braided stainless
steel oil feed hose to the elbow fitting. Cover the open
end of the hose with tape during installation.
attachment.php
attachment.php
now moving on back in order;
14.Bend firewall lip back as far as possible, on right
side of transmission tunnel, for installation of
exhaust piping. Use adjustable wrench to grip lip as
deeply as possible and bend entire seam back parallel
with bell housing. A 3’ to 4’ piece of pipe or metal bar
may be used as a lever against the seam to flatten the
metal. NOTE: If access to a Sawsall or an air chisel is
available, a series of cuts in the firewall lip will ease the
bending operation. Some truck models incorporate an
additional floorpan heat shield behind the firewall lip.
It may be necessary to reshape this heat shield to provide
additional clearance during exhaust system installation.
See Figure 10.
A. On automatic transmission models, and 5 speed
models, saw the “ear” off the right side of the transmission
case in the bellhousing area. See Figure 11. A
Sawsall or coarse tooth hacksaw works well.
B. On automatic transmission models, install o-ring
on new dipstick tube. On C-6 transmission models, bolt
new dipstick tube to bellhousing with original bolt. On
E4OD transmission models, attach dipstick tube to rear
of right cylinder head using a 3⁄8 – 16 x 3⁄4” hex bolt, 3⁄8”
S.A.E. washer and 3⁄8” split lock washer. To align bolt
tab on new dipstick tube, carefully bend lower half of
dipstick tube.
15.If vehicle is equipped with a plastic acoustic
shield on the firewall, cut and remove a section
as shown in Figure 12.
A. On ’83 to ’92 models, remove the screws holding
the vacuum hose junction block, located on firewall
above engine, and lift block upward as far as possible
(do not disconnect any vacuum hoses). Temporarily
retain the junction block up, out of the way, by tying
with heavy string or other means.
B. Wrap the throttle cables and plug wire loom with a
3” x 16” aluminum foil heat blanket starting above the
driver’s side intake manifold bolts and working around
toward the forward end of the throttle cables. Secure
blanket with three cable ties. See Figure 13.
C. Install the glow plug wire loom heat shield between
the intake manifold block-off plate and the flat washers
on the bolts. Position the throttle cables and heat blanket
under the heat shield, then tighten the bolts.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
stay tuned to log truck here on channel 444,as the main turbo kit pieces will be installed next!;Sweet
FORDF250HDXLT
Maine & Oklahoma
max 10 attachments per post........extra attachment post.........
FORDF250HDXLT
Maine & Oklahoma
tonight on log truck...........the sidewinder installation continues with the most time consuming and difficult parts.
this is where a few knuckles get bloody and a few choice words can be heard from afar lol.if you've never installed a banks sidewinder,your missing out on how tight this kit is.it's almost insane how precise everything has to be to fit just right.these suckers are so snappy and increase power so much over n/a though it's so worth the effort.so onward we go.......
16.Install a 7⁄16 x 13⁄8” long stud in the side of the
turbo flange on the turbine inlet casting. Use
anti-sieze compound on the stud threads.
Install turbine inlet casting from under the vehicle by
guiding the turbo mounting flange up and along the
junction of the engine and the transmission adapter
plate. The casting will have to be rotated counterclockwise
as it is raised to a point where the support foot
(Figure 14) can be hooked over the top edge of the
bellhousing flange to rest on the engine-to-transmission
adapter plate. Guide the casting onto the exhaust
manifold studs. Install two 7⁄16 SAE washers with the
original nuts on the exhaust manifold studs.
Caution! Do not drop anything into the turbo mounting
flange opening. Any item dropped into the turbine inlet
casting will cause immediate turbocharger damage upon
startup.
A. Install four 3⁄8” diameter, 11⁄2” long studs in the turbo
mounting flange. Install a 1⁄2” diameter, 13⁄4” long stud in
the rear of the turbine inlet casting, behind the turbo
mounting flange. Use anti-sieze compound on the
threads.
B. Install the rear turbine inlet casting support brace
where the upper lefthand transmission bolt was
removed. On automatic transmission models, install
the brace with a 1⁄2 – 13 x 21⁄4 inch hex bolt through the
round hole (not the slot). Make sure the stud on the
rear of the turbine inlet casting is positioned in the slot
on the brace. Lightly snug the bolt.
On manual transmission models, install the brace
with a washer between the brace and the transmission.
Use a 1⁄2 inch SAE washer on 5-speed models, or
the 3⁄16 thick spacer washer for the 4-speed models. If
the vehicle uses a loop clamp at this location, first slip
the 1⁄2 inch bolt through the clamp before installing the
bracket.
C. Use a 1⁄2 – 20 collet stainless locknut and 1⁄2 inch
SAE washer on the stud at the top of the rear support
brace. Snug the nut and washer against the brace finger
tight. See Figure 16 for correct locknut installation.
attachment.php
very important.this foot on the turbo pedestal (up pipe) must be fully placed up on the engine block.too far back and down on the trans lip and you'll never fit the part.extremely important to note this position:
attachment.php
attachment.php
stay tuned right here on channel 444 as log truck gets it's turbo placed under the hood very,very soon now.;Sweet
FORDF250HDXLT
Maine & Oklahoma
it's the moment you've all been waiting for tonight on log truck (well ok,maybe just me lol) as the banks turbocharger finds it's new home under the hood!............
yeah,it's more of the hard stuff.fitting the turbo bolts on without dropping washers or nuts....fitting that monster dp (the wrap doesn't help) down into what seems to be an impossible fit.........and then the joy of bolting up the turbo drain with gasket.that's not exactly easy either.
be prepared for more choice words and bloody knuckles as you move forward with step 17.............
17.Important! Alignment of the turbocharger and
intake components is determined by the tightening
of the two lower nuts where the inlet casting
bolts to the exhaust manifold. The following outlines
the alignment procedure.
A. Install exhaust gas temperature pyrometer probe in
the 1⁄4 NPT boss near the turbo mounting flange. Use
anti sieze compound on the probe threads. If a pyrometer
probe was not supplied, install a 1⁄4” NPT hex pipe
plug.
B. Install the 5 inch diameter o-ring on the intake manifold
inlet flange (make sure surface is free of oil, dirt,
old gasket, etc.).
C. Temporarily set the turbocharger in place on the turbine
inlet casting and secure it with a couple of 3⁄8 – 24
stainless collet lock nuts, finger tight.
D. Set the pressure chamber casting in place on the
intake manifold. Make sure the pressure chamber
drops over the o-ring. Install the pressure chamber
with a 3⁄8 – 16 x 4” bolt, 3⁄8” AN washer, and 3⁄8” sealing
(o-ring) washer. Lightly snug the bolt so the pressure
chamber can be rotated slightly on the intake manifold.
E. Adjust the position of the turbocharger and pressure
chamber to provide the best side-to-side line up
of the turbo compressor hose joint while providing
clearance between the turbine heat shield and the firewall.
Additional firewall clearance may be obtained by
slightly bending the turbine heat shield at either side
of the slit in the shield. The turbine inlet casting can be
adjusted for position by tightening the two nuts at the
exhaust manifold studs. Start by alternately tightening
the nuts until they are evenly tight against the casting
flange. If the side-to-side alignment is off, the turbo
location may be adjusted by tightening one nut and
backing off the other. Tightening the outside (upper) nut
or loosening the inner (lower) nut will drop the turbo
compressor hose joint while moving it slightly toward
the driver’s side of the vehicle. Reversing the tightening
will reverse the movement of the turbocharger.
Optimum positioning should provide approximately 3⁄8”
gap between the turbo/pressure chamber hose joint
while maintaining firewall clearance and about 3⁄16”
gap between the pressure chamber and turbocharger.
Rotational alignment of the hose joint may be adjusted
by squeezing the compressor snap ring (use Snap-On
No. <acronym title="Page Ranking">PR</acronym>-569A snap ring pliers or equivalent) and rotating
the compressor housing. See Figure 17.
F. Once the best alignment of the turbo and pressure
chamber has been established, tighten the nut and bolt
to secure the rear brace to the turbine inlet casting
and the transmission. Make sure both nuts at exhaust
manifold are tight. See Figure 15.
G. Install the side support brace between the turbine
inlet casting and support bracket on the intake manifold.
The end of the brace with the greater bend goes
against the bracket. See Figure 15. Use a 7⁄16 – 20 x 11⁄4
long hex bolt, 7⁄16 – 20 nylock nut, 7⁄16 – 20 stainless collet
locknut and three 7⁄16” S.A.E. washers. See Figure 16 for
correct locknut installation. Tighten nuts and bolts at
side brace and intake manifold bracket.
attachment.php
optional step: this is a good time to install a turbo blanket in place of the heat shield.i used the same one i used on chip truck:
CXRacing #1078107002413 (GT28 GT25 Turbo Heat Shield Blanket Fiber Glass Black)
why? keep that heat in to reduce under hood temps and quicker spool (increased turbo whistle) .....no one likes turbo lag!
attachment.php
attachment.php
attachment.php
18.Remove the turbocharger and pressure chamber
from the engine. Cover the turbo flange
opening and intake manifold openings.
attachment.php
attachment.php
19.Install oil inlet block an o-ring on turbocharger,
using two 8mm x 30mm hex bolts (bolts are
gold colored for identification) and two pairs (4 total)
of ramp lock washers. See Figure 19 for proper installation
of ramp lock washers. Install a 1⁄8 NPT x – 4 AN
elbow fitting in the oil inlet block. Use Teflon tape on
the elbow threads. Aim the elbow as shown in Figure
18.
A. Run a bead of silicone sealant around the oil drain
tube about 1⁄4” up from the unflanged end. Insert the
drain tube into the grommet behind the intake manifold
while keeping the throttle cable(s) and wire loom
between the oil drain tube and intake manifold. Push
the drain tube about 1⁄2” into the grommet.
B. Install the turbocharger on the turbine inlet casting
using four 3⁄8 – 24 stainless collet locknuts and four 3⁄8
AN washers. No gasket is used between the turbo and
the casting. The upper nut on the driver’s side can be
more easily accessed by reaching between the turbo
compressor cover and the firewall on the driver’s side.
C. Bolt the oil drain tube against the flange on the bottom
of the turbocharger center bearing section. Use
a drain gasket, two 8mm x 20mm hex bolts (bolts are
gold for identification) and two pairs (4 total) of ramp
lock washers.
D. Place a 21⁄4” diameter hump hose and two No. 36
hose clamps onto the turbocharger compressor outlet
connection.
E. Set the pressure chamber onto the intake manifold
with 5” o-ring in place. Install the center bolt, AN
washer and sealing washer. Align the pressure chamber
and tighten the center bolt. Make sure the pressure
chamber contacts the intake manifold so no gap exists
at the junction. This assures that the o-ring is captured
and sealing.
F. Center the hump hose between the turbo and pressure
chamber, then tighten the two hose clamps.
NOTE: On C-6 automatic transmission models, check
that transmission kick-down rod does not bind or hang
up on anything in the vicinity of the turbocharger.
G. Bolt the anti-depression valve to the turbo compressor
inlet elbow using the original bolts. Hose nipple on
anti-depression valve must be oriented up. An optional
valve adapter is required on pre-’87 models.
H. Slide a 3” diameter by 17⁄8” long silicone hose and
two No. 52 clamps onto the compressor 11 inlet of the
turbocharger. Install the compressor inlet elbow into
the 3” silicone hose. Do not tighten hose clamps. Install
two 3⁄8” x 1 1⁄2” long studs in the two threaded holes on
the intake manifold, near the driver’s side of the injector
pump.
Install the air filter support bracket over the studs
using two 3⁄8 – 24 nylock nuts and two 3⁄8” AN washers.
Leave the nuts loose enough to adjust the position
of the bracket. NOTE: Make sure the latches are
in a raised position before tightening nuts or latches
will not clear pressure chamber.
A. Slide air filter into filter housing. The step on the
small end of the filter should extend about 1⁄8” through
the plastic housing to support and center the filter.
Push the filter all the way into the housing.
B. Position a No. 74 hose clamp over the neck of the air
filter. Place the rectangular projection on the bottom of
the filter housing through the corresponding opening
on the filter mounting bracket. Slide the filter/housing
assembly rearward in the bracket while guiding the
turbo inlet elbow into the air filter neck until it stops.
Now tighten the two No. 52 hose clamps at the turbo
and the intake elbow. Push the filter and filter housing
forward within the confines of the slot in the air filter
bracket, then latch the filter housing in place. Make
sure the front end of the filter projects 1⁄8” through the
filter housing. Now tighten the filter bracket bolts and
the No. 74 hose clamp at the filter neck.
NOTE: On air conditioned models, one refrigerant hose
passes over the air inlet elbow. To prevent this hose
from putting undue pressure on the air filter neck or
rubbing on the air inlet elbow, it can be lifted somewhat
by one of the following methods. If the hose does
not rub on the air inlet elbow, proceed to Step 20.
attachment.php
attachment.php
attachment.php
20.On models with a threaded hose connection
at the air conditioning compressor, carefully
loosen the nut on the hose connection just enough to
rotate the hose into a more desirable position providing
additional clearance. This can usually be accomplished
without the loss of any refrigerant. Tighten the
nut when complete. On models where the hose terminates
into a bent steel tube section and is bolted to the
compressor, carefully bend the steel tube section up
slightly to raise the hose. Slide the factory protective
sleeve on the hose to a position adjacent to the windshield
wiper motor, then tie the hose to the motor with
a cable tie wrap to pull the hose up and away from the
inlet elbow. See Figure 20,21.
On late model vehicles where engine intake air is
drawn through a plastic duct from over the grille, the
duct must be cut just where it begins the last bend,
see Figure 22. Some early model vehicles where duct
comes from below battery may require similar modifications
if inlet hose kinks.
A. Install the factory flexible air inlet hose between the
air filter housing and factory air inlet duct. Check that
brake line tube from master cylinder does not rub on
flex hose. Carefully bend tube if required. NOTE: On
late model vehicles where engine intake air is drawn
over the grille, trim the padding away from the underside
of the hood above the air inlet as shown in Figure
23. This prevents the padding from being sucked up
against the air intake and blocking air flow.
attachment.php
temporarily skipped: my auto meter sending unit is too long to fit.i'll need different fittings/bushings.
21.Install the factory oil pressure sender in the oil
inlet block on the turbocharger. Use teflon tape
on the threads. On early model vehicles which use the
large diameter pressure sender, install a 45° brass street
elbow between the turbo and the sender to clear the
turbo. When sender is installed, reconnect sender wire
from wire loom. Make sure wire is routed away from hot
turbo surfaces. See Figure 18.
A. Connect the turbo oil feed hose to the elbow on the
turbo center section.
B. On wastegated models, connect the 3⁄16” nipple on
the turbocharger compressor to the wastegate actuator
diaphragm (on turbine housing) using a 3⁄16 x 10” silicone
hose and two spring band clamps.
first part of 22 only.the dp install.this is where i left off.
22.Install the 7” x 24” heat blanket on turbo downpipe.
Form heat shield to the pipe to allow protection
for the firewall. Secure using wire ties provided.
Drop the turbocharger exhaust outlet pipe between the
rear of the engine and the firewall. Start by lowering
the pipe with the flared end pointing toward the passenger
side of the vehicle (away from the turbo), then
rotate the pipe clockwise as it is lowered. Install the
V-band clamp to couple the outlet pipe to the turbo.
Check that the outlet pipe is reasonably centered on
the outlet flange of the turbo as the clamp is tightened.
Leave the clamp just loose enough to allow the outlet
pipe to move slightly for exhaust system adjustment.
A. Remount the vacuum junction block (if removed) on
the firewall, relocating it upwards as required to provide
maximum clearance to the turbocharger and exhaust
outlet pipe. Drill new mounting holes to suit and reuse
original sheet metal screws.
NOTE: On C6 automatic transmission models, reconnect
transmission modulator hose and tube. Route hose
away from hot turbo and exhaust piping.
Install pyrometer (exhaust gas temperature) gauge and
any other optional instruments. Instructions for pyrometer
installation are supplied with the pyrometer instrument.
Route all wiring away from heat sources, moving
parts and sharp edges.
NOTE: If an optional turbo boost gauge (available from
Banks) is not to be installed, install a 1⁄8” NPT pipe plug in
the port on the passenger side of the pressure chamber
casting (plug is supplied with turbo system hardware).
attachment.php
attachment.php
attachment.php
phew!!!!
that's the last of the tough part.it's all downhill from here.bringing it to you live (almost lol) right here on channel 444!
stay tuned as log truck's turbo gets finished up and then it's onto the 3.5" exhaust system very soon! hope your enjoying the the log truck show!;Sweet
FORDF250HDXLT
Maine & Oklahoma
10 image limit.additional post image attach............
FORDF250HDXLT
Maine & Oklahoma
tonight on log truck..............the banks turbocharger install draws closer to the finish line with the final touches only left,and a 3.5" monster exhaust system gets installed!;Sweet
so continuing on where i left off.the second part of step #22.which is the install of the egt and boost gauges.
the used kit came with good gauges.pyro,lines and boost tube.all i had to do was supply the 2 gauge pod for an under the dash install.i had this on hand too as i took it out of chip truck when i added an oil temp gauge down there.
wire loomed and wire tied up the line and tube for a clean install.
iv got to run some power to the gauges for lights,but i can do that tomorrow.
attachment.php
attachment.php
attachment.php
23.Install the crankcase vent hose between the
antidepression valve and the crankcase vent
adapter on the front of the engine. Use two No. 16 hose
clamps.
attachment.php
24.From under the vehicle, install the exhaust
cross-over pipe assembly between the left
exhaust manifold and the turbocharger inlet casting.
Reuse original nuts on left manifold studs. Use two 7⁄16 –
20 stainless collet locknuts and two 7⁄16 SAE washers on
the turbo inlet casting studs.
attachment.php
attachment.php
attachment.php
25.Install Banks muffler and exhaust system working
back from turbocharger outlet pipe. See
Figure 24. Because of various vehicle/chassis combinations,
some installations will require an extension
pipe.
NOTE: The factory muffler and exhaust system is NOT
suitable for turbocharged engines.
The Banks “standard”
and “monster” exhaust systems are specifically
designed for use with this turbocharger system.
The use of any other exhaust components may result
in significantly inferior performance and may cause
excessive exhaust gas temperature. The use of a Banks
exhaust system is required for the turbo system to be
emissions legal.
25.(i know another 25? misprint probably.step 26 we'll call it.)
Now that the complete exhaust system is
installed, go back to the turbine outlet pipe and
tighten clamp to approximately 25 to 30 inch pounds.
so i didn't use an exhaust kit from banks.i went with my own custom setup.same as i did with chip truck.are you getting the idea that i think i did a lot of things right with the f250,so i just keep coping almost everything? lmao.well i feel i did so here it is.
detailed exhaust part list.in order of flow:
banks down pipe.
banks intermediate pipe (just front section.) this connects the odd sized banks dp to a 3" pipe and bends down to be parallel with the trucks underside.came with kit this time! saved me some coin.nice bonus.
3" to 3.5" adapter - walker 41981
a stick of 3.5" pipe
"big truck muffler" - walker 21470
short section of 3.5" pipe (just enough to hook muffler to adapter below)
3.5 to 4" adapter - summit 652269
4" tail pipe - dynomax 54387
then some clamps and hangers of course.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
this concludes the banks final steps of the 2nd generation (current latest production kit) banks sidewinder turbo!
so iv just got to hang and snug up the exhaust,hook up some power to light up my gauges,hook in my oil pressure sending unit and then it's onto the "final checks" of the instructions! (prime oil to turbo and fuel to ip etc.)
on the home stretch now! stay tuned to channel 444 as log truck is soon to get her whistle!;Sweet
FORDF250HDXLT
Maine & Oklahoma
additional image attach post.........
FORDF250HDXLT
Maine & Oklahoma
tonight on log truck.............log truck get's her whistle! she's officially turbocharged and running smooth as silk.;Sweet
so i finished up the last of the big project with hanging the exhaust.
attachment.php
attachment.php
followed by removing the oil block so i could remove a long bushing and install a short bushing and then my auto meter oil pressure sending unit.
attachment.php
lastly was onto banks final instructions with:
FINAL CHECKS:
A. Check to be sure the injector return hose does not
rub on firewall lip or any other sharp edges. Reconnect
battery cables.
B. Disconnect oil feed line connection at the turbocharger.
Crank engine until oil flows from feed line and
crank another 5 to 10 seconds. Cranking time should
be limited to 20 to 30 seconds, followed by one minute
of cooling. This cycle should be repeated as required.
C. Reconnect wires to injection pump. Start engine.
It may not start immediately, due to fuel lost when
adjusting the injector pump. Observe the cranking recommendations
noted previously. It also may be necessary
to depress the accelerator pedal somewhat.
CAUTION: Visually check the installation for any
improperly installed components, improperly routed
wires and hoses too close to hot exhaust, turbo components,
or sharp edges.
D. Run engine at idle for a few minutes, to allow it to
warm. Check oil feed lines for leaks. Engine may idle
erratically or surge until air is fully purged from fuel
system.
Drive vehicle. Several short bursts of acceleration are
required to completely purge the fuel system of air.
The engine may run slightly rough until the purge is
complete, but will not in any way cause damage to the
engine.
attachment.php
once i had oil after two 15 second crank sessions with the FSS still disconnected,i hooked the supply line up to the turbo and cranked for another 20 seconds.
the batteries were getting tired after this since the truck has been sitting in the cold without running/charging.i put the battery charger on 10 amps.hooked up my FSS and went to lunch.
when i came back in 20-30 mins i attempted to start the truck.........3-4 seconds and she was just running.she starts like chip truck does.issue free with no bleeding bs of any lines and smelling like diesel even after draining the ip.
the pyro started working and i let her idle.she's not yet tagged or insured,so i can't drive it,but i goosed it a bit in the yard and she read an instant quick snap of 5 lbs........log truck is now turbocharged.
until the next project here on channel 444,i hope you enjoyed this episode of log truck.;Sweet
Don't think I'll have a Heart attack, but am having a little trouble breathing, Combivent helps a little, could be from 70 yrs. of smoking. Dr. said quit smoking, Naw, I'll just wrap the ends with Teflon tape, what say you riot. :rotflmao:rotflmao:rotflmao[/QUOTE]
Not sure if this is directed at me...
However we can lead em along but choices must be made for what ever reason they feel they need to make them. We know what works, what can work for this exact application and not run the risk of tape contamination.
If it bites him in the end...oh well. I surely hope it's a HUGE success not another failure.
Now for the build, wicked cool and I'm not sure why you have a 10 image limit I've got 15 image limit including smiley faces and so forth.
Awesome job and I'm hoping to mod the firewall without having to bend it all up, I plan to cut/weld in a panel for DP clearance
Keep up the great work and sure hope see some video soon of this running!
Thanks for sharing!
FORDF250HDXLT
Maine & Oklahoma
log truck is back! in this episode of log truck here on channel 444,it's the installation of a FMIC (front mount intercooler) .......an exact copy of chip trucks FMIC install!
in the order of airflow;
hot side.turbo out to intercooler:
use existing blue banks 2.25" Hump Hose Coupler w/ upgraded T-bolt clamps 2 x 2.25" T-bolt clamps
1 x 2.25" Aluminized Steel, 3.00" Radius, 45 Degree Mandrel Bend
1 x 2.25" Silicone Straight Coupler with 2 x 2.25" T-bolt clamps OR a weld.
1 x 2.25" Aluminized Steel, 3.00" Radius, 90 Degree Mandrel Bend.
1 x 2.25" Silicone Hump Hose Coupler with 2 x 2.25" T-bolt clamps.
1 x Silicone Reducer, 90° bend - 3.0" to 2.25" with 1 x 2.25" T-bolt clamp & 1 x 3" T-bolt clamp.
.............. CXRACING #IC0022-BLK (or simply #IC0022 for non treated/bare aluminum) intercooler...................
cold side.intercooler to engine intake:
1 x 2.25" Silicone Straight Coupler with 2 x 2.25" T-bolt clamps OR a weld with 1.5" section of 2.25" pipe.
into 093 ATS ('93 & '94 factory turbo) pressure chamber.
the install of this FMIC w/ 2nd gen banks wastegated sidewinder into the 9th gen truck,is very straight forward and takes just a few hours.
if a guy had a welder,no doubt the job wouldn't even take a whole day.
so i started by removing the grill.
attachment.php
then i removed the aux tru-cool trans cooler and the vertical rad brace (this is so the cooler can fit in close to the a/c condenser.) though the intercooler would slide up and in,in this truck without plow frame push plates,i went ahead and cut out the grill support T just the same as i had too,to install the cooler from the front into chip truck.i did this,so as to reduce air blockage as much as possible.which in turn raises the efficiency of of the cooler.
attachment.php
fab up some L-brackets out of some steel stock.
attachment.php
attachment.php
so now with the intercooler installed and mounted via the top.
attachment.php
attachment.php
next i put the 90° reducing boots on temporarily to mark where my 2.25" pipes wouldn't clear.
attachment.php
attachment.php
now,you can see the boots wont cut though over time due to flexing/vibration now that they're clear of rubbing the rad support.
such a nice solid rad support,kinda makes ya cringe to cut it up,but knowing what an intercooler does,makes that feeling go away real quick.
attachment.php
attachment.php
so i used a drill bit to ream around the inlet so the reducing pipe could slide into the pressure chamber,so i could fab up an inexpensive,quick and easy intercooler pressure chamber,using the factory 93/94 turbo/aftermarket ats unit.once the pipe fits,tap it down in past the o-ring groove for smooth air flow, jb weld to seal,then install a hump hose.
attachment.php
attachment.php
place the grill back on.i simply screwed on a thin vertical strip for the grills bottom screw.as you can see,i ran out of time.the trans cooler is just hanging up there.i now need to just shorten the lines,and mount it down lower.i'll be cutting the center holes out and installing the 9th gen bumper cutouts like seen on EB f150's and all 94-97 psd trucks.
(this bumper w/ center cutouts is what i replaced chips with too)
this will allow all the airflow i'll need to trans cooler without stacking too many coolers up in the grill area (which i know is too much from experience.)
attachment.php
so lastly,then i'll just install the pressure chamber,mark my pipes and take them up to the local welding shop and then install them.
then,it's back to the IP to turn up it's fuel screw.......all the way.;Really
attachment.php
stay tuned to channel 444 as the FMIC on log truck is to be concluded soon.
FORDF250HDXLT
Maine & Oklahoma
extra image attach post.........................
dieselmainiac
