InnovativeAV
So I was up on the highway today doing about 60 mph. And my speedometer started bouncing all over.
Another place to check is the speedo gear in the trans. When I bought my truck the speedometer was fluttering quite a bit. I was told to replace the VSS on top of the rear diff. I did and still had the problem. Took out the speedo gear in the trans and the teeth were chewed up on the plastic gear.
Could be the speedo gear in the rear axle, I have that problem but I just removed the gear since im running 46's and its 20mph off and I use my phone gps speedo
BTW the ring gear teeth will take out that gear... Sorry to make u wonder now but that's what happened to me
What does the electromagnetic sensor run off of? A gear.
