1989 F-250 7.3 Project
chillman88
Central NY
Sweet! Let me know how that heater works. I still need to get something other than just the coal stove in my garage. Would be nice to keep it above freezing all winter.
hacked89
Bucks County PA
Will do. I'm going to try it first without isolating/insulting the ceiling off from the working area. It will be more costly but I like the fact that all the fumes and gases rise out of the personell area. Then the fan can clear them out easy. I know if I sealed it off it would get cozy.
Sent from my SM-G955U using Tapatalk
This is why I'm getting ready to hang 1/4" plywood on the bottom of the rafters in my garage. The walls are insulated, but the heat from my wood burning stove escapes through the roof. With the stove and all of the fire wood that I have, I hate not being able to work in there when it's less that about 25 outside. Did I mention that I'm a wimp when it comes to the cold?
hacked89
Bucks County PA
Worked on the truck today. 30 degrees here and it stayed in the mid to upper 50s in the garage. While wrenching I was almost too warm in a heavy sweatshirt and long sleeves.
hacked89
Bucks County PA
See what I posted a minute ago to chill. Also, with the shuttered industrial fan that I had framed into the garage ceiling wall I can leave the garage doors closed and cross ventilate from a side door out the fan. When welding I actually feel better ventilated then when taking class in a shop with dedicated booths.
I've decided I'm not going to seal off the ceiling.
hacked89
Bucks County PA
Today.
In the continued effort to save this trucks life, the frame was rusted through around the driver side leaf spring perches. First I punched out the rivets.
Template
Another shot with some cleaning
I have a bunch of steel. At this point I cut the template out and was like yea this doesn't seem like 1/4". It was 3/8". I didn't have enough 1/4" plate dimension to tail out in a single piece so I did it square. In this application I dont have a concern. For the loading principle I would actually debate whether the vertical welds should even be there, but I did.
Holes drilled
Laying the first beads down
Done and coated
Bolted.
hacked89
Bucks County PA
Sunday.
Stripped the accessories and most of the harness from the engine in the truck.
Fabrication shop near me went out of business. Picked up 560lbs of fresh steel at .25 cents a lb. Here's some of it. Convenient timing for the run stand I am building.
Next, started to strip the second motor I will be using for testing, measurements, and fabricating the run stand.
Removed the harness and accessories.
Going to document it, interesting to see the history and mysteries of a motor uncovered.
I was mildly surprised when I removed the bottom bolt from the alternator bracket oil came out.
When the motor was pulled they snapped the line in the filter head from the lift pump. Got to get a new line and maybe a new filter head if I cant extract it. Looks like someone maybe have used loctite. Also need to get vibration dampeners for one of the return line sides.
Finally took a look under the driver side valve cover.
bbjordan
Snow Monkey
Ashern Manitoba
With some heat to melt the locktite and expand the aluminum housing, you should be able to extract the brass fitting with an EZ-out.
hacked89
Bucks County PA
Drivetrain out.
Bodywork - earlier in the thread I cut and welded in the front lower door pillar. I wasnt happy with that cause the rocker was missing the metal weatherstripping ridge. So i cut out the new lower pillar I welded in. And then I cut all of the rockers out on both sides. And then I cut the cab corners out both sides. Then I went to town on the floor with a sledge hammer wherever there was rust.
I ordered seam sealer for the floor and it's going to be here Thursday. Next goal is to have the driver side of the truck all welded and patched together by EOD tomorow. Passenger side done by EOD Wednesday.
Thewespaul
Bulverde, Texas
Man I’m pretty behind on this thread, sounds like you really went to town on that cab. You can junk the filter housing with the broken fitting, with the dual filter head I sent you, you won’t need it or the line from the lift pump. Engine looks good under the valve covers, not too sooty and all the push rods are installed correctly, I can see a few exhaust valve seals and they look intact which is a good sign that the engine hasn’t gotten very hot or a ton of miles.
hacked89
Bucks County PA
Yes, more pics to come on the cab. By the way your comments and under the valve covers I posted are from the second motor that I got from a parts truck on craigslist.
The original motor from the truck (but was from an ambulance) that is getting built I didnt open up yet.
The motor that was pulled from the truck and is getting built had the following compression #'s.
420,420,380,395,395,395,395,350
hacked89
Bucks County PA
Driver side.
Rockers, pillars, cab corner, floorpan, patching.
Thewespaul
Bulverde, Texas
There’s a lot of work tied up right there. How does the panel lip under the master cylinder look on the firewall? That’s a bad spot on the race truck, it’s got me considering cutting out the firewall completely.
