09S09 Recall Notice
Diesel Max
93 F-250 4X4 - 7.3
New Mexico
Just got a 09S09 - Speed Control Modification Recall Notice today. Anyone else get one these ?? Anyone know what the fix involves ??
Russ
Idont do injectors
New Brighton PA
it just stops wiring from shorting out and catching fire. if the sensor on the master cylinder starts leaking. It''s an inline fuse that goes near the master cyl.
Got one way back in early November. Haven't had time to take it in. No big deal, from what I've heard only takes about half hour.
Diesel Max
93 F-250 4X4 - 7.3
New Mexico
Ok thanks for the info............ Cruise control doesn't work, I don't suppose that will fix it either. Only thing on the truck that doesn't work and I have never really had time to dig into it and find out why it doesn't work.
itsacrazyasian
residentcrazyasian
boca raton, fl
pull the plug on the master cyl in the mean time so it doesnt set the truck on fire. I lost a Explorer because of it.
94turboidi
Ne So. Dakota
Mines not even hooked up now since I did the hydroboost the f450 master cylinder didn't have that sensor. I do have the upgraded harness that they plug into your wiring and plug into the sensor. I got it off a parts truck that they must have taken in for the recall. I had it on my truck for a while. It looks like it just puts an inline fuse in the wiring. There is a sticky on here about the recall notice.
Popeye2347
Winchester, Illinois
3'rd sticky from the top-read all about it....
2x remove the wires from the master cylinder until you get the recall done.
FWIW it took all of 3 minutes for the tech to install the inline fuse on my IDI F250. All done in their parking lot adjacent to the service counter.
