Idi extreme coolant pressure/leakage
Roil Burner
Putnam, CT
Bubble+overflow on less than a min of run time. Also notice a slight black swirl of something in the coolant.
This thread is not old enough to disregard a thank you to Cole250 for the bubbling coolant photo. Given all the swollen rad hose posts in the forum, this is a solid check before jumping to conclusions (blown gaskets, cracked block/heads, cavitation etc).
Did you investigate or crank on those head bolts?
IDIBronco86
