I broke lots of **** on my injection pump
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
So there is an arm on the drivers side of my injection pump that I broke. What is it and where/how do I get a new one?
Also broke the return line inlet off. The threads are stuck in the top. Damn I’m stupid
I believe that's the timing advance arm. I don't know if you can get a new one, but you can probably get one off of another pump. One of the rebuilders may have a pump that's junk and would sell you the arm off of it. If you're careful, you may be able to use a screw extractor for the return fitting. Before trying that, you may want to try a flat tip screwdriver. you may be able to press one against the threads and unscrew them. If you do try any of these things, be aware that you may end up getting pieces of the fitting inside your pump.
Black dawg
sw mt
Probably be best to find another pump, unless you are really lucky or know how to gt the advance function adjusted back to the way it should be, timing will be all messed up. Not bad enough to not run, just the advance curve.
IDIBronco86
