Dyno Day!
03wr250f
Hamilton/Montana
Dyno day!
7.3 tidi r&d cold air intake, downpipe, stage 1 injectors, stage 1 drop in turbo, factory turbo cal ip maxed, stage 3 fuel system, hypermax intercooler, head studs, valve springs, SB 13" clutch, and water m3th on the last pull.
3.55 gears, zf5 dynod in 4th (1:1) 285/75-16s
david85
Campbell River, B.C.
Maybe I've been out of the loop for a while, but that's the highest IDI dyno run I've seen. Most struggle to break the 250 Hp level claimed by the original turbo kit manufacturers. Congrats.
Reggie f250
Bartlett il
Very nice! Hope mine can do that someday! Where did you get the handle on the passenger side pillar?
Chemgrad
NC
Nice. When you say the IP is maxed out is that max factory or max aftermarket? Those torque numbers are freaking sweet.
IDIBronco86
