ZF advice/help please
Kizer
Denton, Texas
I’m on round 3 of output shaft seal (rear seal) replacement.
I broke the trans, replaced it with rebuilt transmission…seal leaked and I ASSumed that the seal leaked because I had stored the trans dry for a few years.
Replaced the seal…still leaks…read the service manual. Assumed, again, that the new seal leaked because I’m certain that I didn’t get 200 ft lbs of torque on the yoke nut.
Replaced again and leak is worse! I know that I got 200 on the nut.
I don’t understand what I’m missing. Any help will be greatly appreciated.
Kizer
u2slow
bilge rat
Coastal BC
How are you sealing the spline? Is the yoke body smooth without any wear grooves? Is there play in the output bearing?
Kizer
Denton, Texas
I’m using thread sealer on the splines.
The yoke doesn’t appear to be damaged and the trans that I broke received it with no leak.
The output shaft doesn’t deflect and no vibration when driving.
u2slow
bilge rat
Coastal BC
Thread sealer? Is it working, or that the leak source?
My dodge transmission specifies anaerobic sealant (similar to loctite) on the spline, and on diffs I typically use ultra-black rtv on the pinion spline.
Kizer
Denton, Texas
I’m using the Loctite brand thread sealer (white tube).
It looks like the seal is leaking around the outside of the inner part…if that makes sense. I’ve been using National (brand) for the seal.
u2slow
bilge rat
Coastal BC
Wrong sealant... That will have Teflon in it for making threaded pipe joints seal. Doesn't really set up. I use permatex anaerobic flange sealant part # 51531.
I usually put a small smear of rtv on a seal before tapping in into the housing.
Kizer
Denton, Texas
10-4
I’ll give it a run.
Is it possible that I’m seating the seal too far back…or not far enough?
The seal wants to stop about 3/16 beyond flush with the tail housing (inside).
Thank you.
Kizer
Denton, Texas
Quick update: Work (for $) happened.
I hope to get the seal in Sunday.
I’ll update with results.
Other than the fact that time is harder to come by than $, it is nice when $ opportunities show up. Then when time opportunities finally show up.......... you ain't got no $$$! What's up with that?
placidoert
