Guntherx
Well,
we sort of made it to CO. The trip out was BAD
First the power of the truck was not enough. I scaled it at 22,000. We could not run over 60 on the flat and if there was any hill or wind or anything else but downhill it was down to 50 or less. When we hit Kansas and CO it got worse down to 40-50. I averaged about 5.5 mpg and temps about 1200.
Then it gets better. The new US Gear 2 speed had a plug for the light switches that kept loosening up and we were loosing gear fluid. We tried to epoxy it in after tightening it and thought we had it fixed. Then we had a trailer tire blow out (and I mean BOOM gone) in Kansas. We pulled into a small broken down truck stop to call for a tire repair. While we waited I saw that the 2 speed was leaking again and the plug almost all of the way out.
we hitched a ride into the nearestg town (not big) and found an oversize plug that would work. I had to start it in and then take it out to cut the end of it off so as not to hit the shaft that rides behind it.
So, we are on the road again and stop for even more fuel. I see the generator drainsetup falling out of this guy's generator. Pulled it apart and fixed that. Then while trying to back out of a tight spot at a fuel stop the grill that was in the pickup bed poked a hole in the front of the trailer. When it rains it pours. :bleh:
So we made it. It took all 30 hours to get here. We unhooked and went to the high mountains and man you should see my truck smoke.
The high altitude really makes a difference. (12,000 Ft.) I don't know what to do with this truck when I get back. I don't know if the turbo will bring it to life or not.
11 tons is a lot of rig. I can't account for the power loss in Kansas. That doesn't really make any sense, unless it's something in the fuel out there (less BTU's maybe?
Sounds like you had your foot on the floor the whole way across with those EGT's. When you get home, I'd do a compression test and look at your blow-by to make sure you didn't crack a piston. A turbo WILL make a big difference. I know Scott wasn't impressed, but he is the only person I know who was disappointed. And, if it works out that your disappointed too, and for some reason you end up selling your truck, you'd get your money back for the turbo anyway. That sounds like a really simple problem with the US Gear unit, but a pain none the less. Good luck nursing it back home. We wish you the best! Try to meet up with Rob (F350Camper)while your out there. He may be able to help. Heck, maybe he'll cast you a new case for your US Gear unit.
If you don't have a pyro, I would hold off on the pump and injectors until you get the turbo...personally, I wouldn't want to take a pump that's already calibrated for a turbo and mess with the fuel settings, but that's just me.
