Yesterdays Mess
So yesterday I decided to replace my fast idle sender that controls the fast idle solenoid and the cold advance. Mine has been shutting down long before the engine reaches 120 degrees. I removed the sender from a spare head and cleaned it up then used permatex aviation cement on the threads. My 15/16 socket would not fit so I started grinding the top edage of it. After 7 times grinding it to fit. I finally got a flash lite to look in there and see why it was not fitting. Turns out there was not enough room by the intake manifold so thought about grinding it with my Makita long nose grinder with a small ball burr. Then got the idea to look at the spare head and try to see why I was having so much trouble. I even cut down the hex end and ground down the walls to make the socket fit.. No joy. Well as I'm looking at the spare head I noticed no issues with the sender fit. I finally heard the sound of my head popping out of my back side...:rolleyes: What I had done was removed the over temp sender and not the fast idle sender.. What a big messy I made. So I found I needed a 7/8 socket to remove the sender and it fit fine in the new head. All this took about 2 hours of grinding and fitting. Actually ruined a goof Craftsman socket too. No problem.. I have 3 sets around the shop. I once felt it was a good idea to have a set in each car we have.. Well that never really worked out but at least I have the sets available and finding one of three is much easier than finding one of one. I'm really bad at returning things to a known place but I'm getting better at it...:angel:
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
I thoguht half the fun of doing a project was searching for tools/parts that you had set down in the wrong place just a few minutes prior? Does that mean I've been doing things wrong all these years? :D
I once set a Craftsman socket set next to a Kobalt socket set, I'll never do that again, never heard such screeching in my life when they got in a fight about who was the better tool. Now I just buy Evolve tools.
Yes Ken.. All the time doing this job I was thinking that very thought. Glad I saw it thru and figured out what I was doing wrong. But it should not have taken so long to see what was wrong either.
I might not have admitted to doing all that. You're a better man than I am! lol!
idi_econoline
No Bed For Me!
Northern California
Just the confession I needed to read, Gary, as my heads now sit near my block, awaiting reunion. First solo attempt at getting that mess back together, starting a couple of weeks. Expecting a few learning experiences along the way. LOL
Thx for the reminder about the aviation thread sealer. ;Sweet
