WTB: 92-97 F-super duty Auto brake pedal
FORDF250HDXLT
Maine & Oklahoma
WTB: 92-97 F-super duty Auto brake pedal to properly complete my hydroboost swap.
sick of the real hard brake pedal.can't find one for sale.
Make one...I had a pedal setup welded up...just because that damn pin is higher on the arm...looks like it's going to work out well...
JM2CW....
gatorman21218
Ashland VA
Some may frown upon this, but I will take a more effective brake system for a welded pedal. I took a 9/16 grade 8 bolt and drilled a hole where it should go, put it in and had a friend (cert. welder) run a bead around the head on the back side. I then cut it to length and drilled a hole for the cotter pin. just buy a 4-6 in bolt so you have a smooth shaft and no threads when you cut it to length.
And no I would not trust a pin that was butt welded on the pedal. it is going through the pedal and welded, which is no different to me then how the factory did it.
